Poppa G Posted December 11, 2021 Share Posted December 11, 2021 Need a wiring schematic for 2003 HR 40PWD Imperial to show step cover and access to it Link to comment Share on other sites More sharing options...
waterskier_1 Posted December 11, 2021 Share Posted December 11, 2021 I can't find a step cover electrical drawing for 2003 Windsor. I have a basic diagram for 2003 Dynasty which is Air Operated. Is you Imperial Step Cover Electric or Air Operated? Link to comment Share on other sites More sharing options...
Poppa G Posted December 11, 2021 Author Share Posted December 11, 2021 It was always silent operating,never heard an electric motor engaging the cover,so I have no idea what actuates the cover there’s power going from the switch Also having a problem with the keyless entry pad,some of these issues are above my pay scale and patience. Link to comment Share on other sites More sharing options...
waterskier_1 Posted December 11, 2021 Share Posted December 11, 2021 Ok, found the step cover solenoid electrical diagram. I highlighted the circuit. This is from a 2003 Windsor, and I have no idea if yours is Electric or Air Operated. Maybe this will help. 2003 Windsor Step Cover.pdf Here is the 2003 Dynasty Air Operated Step Cover wiring diagram. Hopefully between the two you'll be able to glean what you need. 2003 Dynasty Step Cover.pdf Link to comment Share on other sites More sharing options...
