BFam2008 Posted December 22, 2021 Share Posted December 22, 2021 After having the coach in the shop since July for a engine electrical issue (lost power to ECM/TCM) which will be the topic of another post. I brought the coach home from the shop in Muskogee OK and as I got into Dallas and noticed I had no headlights everything else was working, headlights were dark. I got it home just in the nick of time as darkness set in. I've had a few issues with intermittent headlights, but I looked at the control box today and the Molex connector on the PCB is Charred (picture attached). The wire side of the Molex connector is pretty much toast as well. I could wiggle things and make them work, but in my experience if you can wiggle it and make it work... the loose connection is going to get hot or worse anyway and should be replaced. I replaced the light switch last year because the lights didn't work. Can you still get the control box and maybe the wire side connector from somewhere? Any other headlight suggested fixes would be welcome as well. uq7npo36.bmp Link to comment Share on other sites More sharing options...
Ivylog Posted December 22, 2021 Share Posted December 22, 2021 (edited) I soldered on the back side a 2 plug connector bypassing the burnt plug. The board is only rated for 9 amps but it usually takes 10+ years before probably corrosion builds up and it overheats. Edited December 22, 2021 by Ivylog Link to comment Share on other sites More sharing options...
BFam2008 Posted December 23, 2021 Author Share Posted December 23, 2021 Great minds think alike, I was thinking about pulling out my desolder kit and replacing the connection on the board with wires and a 4 pin connection off the board. Link to comment Share on other sites More sharing options...
StephenW Posted December 23, 2021 Share Posted December 23, 2021 I had a similar problem last spring and I used guidance from other members on this forum to bypass the smart wheel headlight problem. Namely burned connections and circuits. I used the advice I found under the thread titled No Headlights and Relay Solution by Mocephus. It can be found under the Electrical section by searching for the thread title. So far no further headlight or smart wheel problems. Good luck. Link to comment Share on other sites More sharing options...
