BradHend Posted February 26, 2022 Share Posted February 26, 2022 Am thinking about buying the BlueFire adaptor for my coach, and was hoping someone on here may be able to verify a question I have. My coach has a 9 pin diagnostic port in the rear engine bay, and a six pin port in the front cab. The question is, will there be less information available via the 6 pin port, and should I be purchasing the 9 pin extension cable and bring it all the way up front. Thanks, Link to comment Share on other sites More sharing options...
DavidL Posted February 26, 2022 Share Posted February 26, 2022 You need to determine what protocol your powertrain supports. J1708 or J1939. J1939 is newer RVs and uses 9 pins. On the 9 Pins J1708 might also be there. The 6 pin is J1708 (older RVs). Yours likely is the newer, but you should check by sending your VIN or engine serial number to the engine manufacturer. Link to comment Share on other sites More sharing options...
eyeball Posted February 27, 2022 Share Posted February 27, 2022 I just bought one. 2006 hr 40pdq endeavor I had to buy the 6 to 9 adapter everything work 1st time now will not connect. Sending back Monday morning Link to comment Share on other sites More sharing options...
Danny B. Posted February 27, 2022 Share Posted February 27, 2022 I would contact the Bluefire owner, he is really good about geting you are the information you need. I had a similar question and I didnt understand his response but he did dummy it down for me to understand. Link to comment Share on other sites More sharing options...
DavidL Posted February 27, 2022 Share Posted February 27, 2022 It's not just about the number of PINS...its the protocol that is just as important. A pin adapter doesn't change the protocol. Kinda like you can talk to someone via two cans and a string or a cell phone or a speakerphone. but if you speak English and the other Italian...you still will have trouble conversing. Link to comment Share on other sites More sharing options...
BradHend Posted March 1, 2022 Author Share Posted March 1, 2022 From Mark @ BlueFire: “Hi Brad, Since you don’t have a 9-pin adapter in the cab I’m guessing that you just have J1708 in which case it won’t make a difference which port you use. However if the 9-pin port in the engine bay has 6 pins then that port is using J1939 and J1708 and may be better. You can tell by plugging in the adapter into the 9-pin port, check the App Setting ‘Connect to the J1939 Data Bus’ and then see what data you’re getting on the Drive and Repair pages.” I will see what the outcome is when it shows up. Also, Peter - I found the company that custom makes the cables to your spec using the Deutsch connectors. Just have to give them the spec on the pin arrangements. 45’ was not a problem for them, so if the rear 9 pin Connector is indeed better, looks like I’ll be buying and routing it throughout the chassis. www.yasoncable.com Link to comment Share on other sites More sharing options...
