Fresh water holding tank
The main method I use is the pressure fill by turning the lever on the water inlet valve 90 degrees.  You can hear it start filling the tank.
The other method is the gravity fill using the spa hose that goes through the wheel well.   I usually only use this for adding bleach to disinfect/clean the tank.
I had to replace the gravity fill hose as it's exposed to debris from the rear tires and had developed a leak.  When this happens your fresh water tank will only hold about 25% of capacity.
