Cabinet Door Light Switch
Looking for some cabinet door light switches.  We leave the doors unlatched when parked and some of the micro switches I've seen don't have a long enough throw to keep the light off when unlatched.  The bay door pin switches I have are larger than I would like in a cabinet.
48 minutes ago, David Pratt said:
You might want to think about replacing them with motion detection switches.
Go to; Super Bright LEDs, Inc.
314-972-6200
Switch Part Number is; LPIR-6A: Mini PIR switch
That may be the best and easiest solution!
I was looking for a 12 volt source for the galley cabinet lights I want to install.  The only 12 VDC I found in the lower cabinet area was the gas cooktop power on a 2 amp fuse which is shared with the bedroom fan.  With a multiplexed coach there's not much need for un-switched 12 VDC power.
