Lakesidelogger Posted May 27, 2022 Share Posted May 27, 2022 Hello, I have a 2011 Dynasty Regal IV with a heated tile floor. The living area heating is not working. I have new thermostat and have checked for resistance in the wiring. There is none. My question is about the wire routing. I see where the power disappears under the tile directly below the thermostat, but I am wondering if there is and junction box somewhere where the power connects to the heating pads or are the connection just buried in the floor? I know - it’s a long shot but I thought it wouldn’t hurt to ask before I contemplate the “fix”. Thanks in advance. Mike Link to comment Share on other sites More sharing options...
RBRODDER Posted May 27, 2022 Share Posted May 27, 2022 If the floor heaters are heating pads similar to what is utilized in aircraft, there should be measurable resistance since it is basically a heating element? The resistance values should be dependent on the size of the pad. If you are reading zero resistance, then there is a broken wire or an open in the circuit or element. Link to comment Share on other sites More sharing options...
