sg47619 Posted June 20 Share Posted June 20 I’m going to tow my 06 wrangler X manual transmission behind my 01 Monaco Dynasty. How do you set it up too follow the coach when turning ? Link to comment Share on other sites More sharing options...
jacwjames Posted June 20 Share Posted June 20 Nothing special to do other then installing a tow bar and as long as the steering wheel doesn't lock. The Wrangler will follow the coach which ever way it goes. I pull a Jeep GC and don't even know it's there. Link to comment Share on other sites More sharing options...
sg47619 Posted June 20 Author Share Posted June 20 Thanks p, I have the tow bar mounted to the Jeep, just didn’t know if I need something for the steering wheel Link to comment Share on other sites More sharing options...
GNRACN Posted June 22 Share Posted June 22 What are you using for a brake system? Link to comment Share on other sites More sharing options...
jacwjames Posted June 22 Share Posted June 22 When I bought my rig it was already setup with an quick connect for air. I decided to go with the Brakemaster 9160 https://www.roadmasterinc.com/products/braking/brakemaster/brake_m.php Pretty straightforward to install and once in taking the pneumatic cylinder in and out. Works great. I know others recommend others including the Airforce 1 type but I didn't see anyway installing one of those in my Jeep with the Hemi, no room in front of the master cylinder. Link to comment Share on other sites More sharing options...
sg47619 Posted June 22 Author Share Posted June 22 5 hours ago, GNRACN said: What are you using for a brake system? With My 38 foot, 350 Cummins I didn’t think I’d need a brake on the 06 wrangler X. How does everyone wire there tow vehicle, I thought I could back feed it to the jeeps rear hitch but that didn’t work. Link to comment Share on other sites More sharing options...
jacwjames Posted June 22 Share Posted June 22 (edited) I completely bypassed my Jeeps wiring and ran a harness front to back and installed separate light bulbs on each side for turn signal and running light. With the Brakemaster that pushes the brake pedal the brake lights come on whenever you are braking. I did not bother with a charge wire so if traveling extended distances every other day I'll start the Jeep and let it run for a while. While I'm doing this I'll take the time to wash my windshield. Auxiliary braking is required in a lot of states if the weight exceeds pretty low weight limit so it's better to be safe then sorry from a liability basis. My Jeep is ~5000lbs, every little bit helps if you are in a panic stop. One thing I've found is that with the braking system I need to keep my eye on my Jeeps brakes, they definitely wear out faster but IMHO that's a good thing, it shows my system is working. Edited June 22 by jacwjames Link to comment Share on other sites More sharing options...
sg47619 Posted June 22 Author Share Posted June 22 24 minutes ago, jacwjames said: I completely bypassed my Jeeps wiring and ran a harness front to back and installed separate light bulbs on each side for turn signal and running light. With the Brakemaster that pushes the brake pedal the brake lights come on whenever you are braking. I did not bother with a charge wire so if traveling extended distances every other day I'll start the Jeep and let it run for a while. While I'm doing this I'll take the time to wash my windshield. Auxiliary braking is required in a lot of states if the weight exceeds pretty low weight limit so it's better to be safe then sorry from a liability basis. My Jeep is ~5000lbs, every little bit helps if you are in a panic stop. One thing I've found is that with the braking system I need to keep my eye on my Jeeps brakes, they definitely wear out faster but IMHO that's a good thing, it shows my system is working. Thanks for the info. I did receive the roadmaster braking system when I bought the coach but I’m not sure it even works Link to comment Share on other sites More sharing options...
jacwjames Posted June 22 Share Posted June 22 20 minutes ago, sg47619 said: Thanks for the info. I did receive the roadmaster braking system when I bought the coach but I’m not sure it even works Just put some air to the cylinder and if it goes out it works. Pretty simple design. If you decide to use you will need a base plate it the front seat that it will attach to, and you will have to plumb in the air line. I decided to go with the system that included the break away option, this is basically a small air tank that is mounted somewhere in the coach. There is an electric disconnect switch that releases the air if the tow vehicle breaks away from the motorhome. This part is not required for the Brakemaster to work but it adds another layer of safety if something happens. Link to comment Share on other sites More sharing options...
sg47619 Posted June 22 Author Share Posted June 22 1 hour ago, jacwjames said: Just put some air to the cylinder and if it goes out it works. Pretty simple design. If you decide to use you will need a base plate it the front seat that it will attach to, and you will have to plumb in the air line. I decided to go with the system that included the break away option, this is basically a small air tank that is mounted somewhere in the coach. There is an electric disconnect switch that releases the air if the tow vehicle breaks away from the motorhome. This part is not required for the Brakemaster to work but it adds another layer of safety if something happens. Ok. Thanks. Link to comment Share on other sites More sharing options...
GNRACN Posted Monday at 05:34 PM Share Posted Monday at 05:34 PM I too have this system. The EMS or break-away tank has to be mounted in or on the towed vehicle. I went a couple steps farther and added a air regulater to the air cylinder to avoid locking up the toads tires after installing brake pressure gauge in the coach and seeing 60 to 90# brake apply pressure in coach. I set the max pressure in toad to 40#. I also tapped into GC brake light switch wire to a small LED light mounted with vel-cro to wind shield to verify brakes are applying. Toggle switch under dash. Have about 40,000 towed miles on this application, it has worked flawless. I thought that I read where there are only 2 or 3 states that don"t require brakes with break-away feature including Canada on towed vehicle! Link to comment Share on other sites More sharing options...
sg47619 Posted Monday at 11:47 PM Author Share Posted Monday at 11:47 PM 6 hours ago, GNRACN said: I too have this system. The EMS or break-away tank has to be mounted in or on the towed vehicle. I went a couple steps farther and added a air regulater to the air cylinder to avoid locking up the toads tires after installing brake pressure gauge in the coach and seeing 60 to 90# brake apply pressure in coach. I set the max pressure in toad to 40#. I also tapped into GC brake light switch wire to a small LED light mounted with vel-cro to wind shield to verify brakes are applying. Toggle switch under dash. Have about 40,000 towed miles on this application, it has worked flawless. I thought that I read where there are only 2 or 3 states that don"t require brakes with break-away feature including Canada on towed vehicle! Ok thanks for the info Link to comment Share on other sites More sharing options...
