Doug and Nicki Posted July 13, 2022 Share Posted July 13, 2022 We have the five button door entry keypad that is on most of the Coburg built motorhomes. Lately, the door has been locking at random times, without anyone pressing a door lock button or key fob. Have any of you experienced this? If so, what did you find the cause to be? Link to comment Share on other sites More sharing options...
Oregon04Windsor Posted July 13, 2022 Share Posted July 13, 2022 This happened on our 2004 Windsor, I also noticed an occasional, random beeping noise. I unplugged the exterior keypad and all the issues stopped. Still works with the fob. Link to comment Share on other sites More sharing options...
Doug and Nicki Posted July 13, 2022 Author Share Posted July 13, 2022 Thanks for this information. I may have to do that as well. I will play around and see what other input I receive. If I find the solution, I will let you know. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted July 17, 2022 Share Posted July 17, 2022 On 7/13/2022 at 10:11 AM, Oregon04Windsor said: This happened on our 2004 Windsor, I also noticed an occasional, random beeping noise. I unplugged the exterior keypad and all the issues stopped. Still works with the fob. It takes 2 actions for the keypad to work. Pressure and the heat from your finger. That prevents the heat from sun light to activate the code. Due to use and wear the pressure on the number does not release. Therefore one of the actions is activated. Then add the heat from the sunlight you get the beeping sound. The only remedy is to get a new keypad. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
