TDaleABQ Posted October 9, 2022 Share Posted October 9, 2022 Hello all, I have a 2007 Monaco Knight SKT. Coming home a couple of days ago, the display on my Voyager B&W monitor was compressed to the center of screen and could not really read it. After a while, the screen just went blank. I know the Alladin is sending info because I can here the beeps if I scroll the buttons on it. I think the monitor just went out but no sure. Any thoughts are appreciated. TDale, ABQ, NM Link to comment Share on other sites More sharing options...
Ktbt21 Posted October 9, 2022 Share Posted October 9, 2022 I had the same problem. I installed a pancake fan above the monitor and removed the insulation around it. This is a common problem with the older crt monitors. Link to comment Share on other sites More sharing options...
Steven P Posted October 27, 2022 Share Posted October 27, 2022 My monitor was bad when I bought my coach. It did numerous wonky things including what you're describing. I purchased a new monitor from Tim at rvcams.com and all is well. Mounted w command strips over the existing hole as it is larger. But, an easy troubleshoot is to stick a small tv on your dash and run RCA cables from the Aladdin to the TV instead of the dash monitor and see if it works. Link to comment Share on other sites More sharing options...
