Joel Sheriff Posted June 4, 2020 Posted June 4, 2020 Can anyone advise how you can lower the angle pitch of the awning down toward the ground. My awning came with the setting in the lowest hole which seems to be the lowest pitch but it sticks straight out from base parallel to the ground. There are five or six holes above the one it's in??
Bob Nodine Posted June 4, 2020 Posted June 4, 2020 You push on the plunger so you can slide the bracket up to the next hole. Move each side one hole at a time and test until you get the angle you are looking for. On our coach we cannot get a decent slope because the awning hits the top of the slide.
Joel Sheriff Posted June 4, 2020 Author Posted June 4, 2020 My son and I both found it near impossible to push in on the hole button and move it either in the open, partially open or closed position of the awning. Also it looked like going from the last hole on the bottom to holes above it world decrease the pitch instead of lowering or dropping the pitch to get it where the top of the awning sloped toward the ground.
