Capt Mike Posted April 12, 2023 Share Posted April 12, 2023 Having an issue with my road side bedroom slide on my 2008 Knight 38PDQ. It will not come in when hitting the switch, it does make a noisy rattling sound and always has. This time it made the noise but didn't move. I have everything exposed to work on the unit which the tag says it is a Lippert above floor sofa slide, LCI model #114754. The motor and gears that I can see are ok. There is a shaft with a hole in it maybe to manually get the slide to move? I may have to give the slide a push from outside? Any ideas from the knowledge base here would be greatly appreciated! Link to comment Share on other sites More sharing options...
96 EVO Posted April 12, 2023 Share Posted April 12, 2023 Can't see it in any of your pic's, but there's usually a place to put a socket on (5/8 I believe), and manually move the slide. Pushing from outside while someone presses switch may also work. Sounds like the clutch system is slipping! Link to comment Share on other sites More sharing options...
Capt Mike Posted April 12, 2023 Author Share Posted April 12, 2023 Looking at Lipperts site I see the 5/8” on slides where the mechanism is located under the slide in the basement. I don’t see it on this slide. Starting to rain here so I’m on standby. Thanks for your input. Link to comment Share on other sites More sharing options...
96 EVO Posted April 12, 2023 Share Posted April 12, 2023 1 minute ago, Capt Mike said: Looking at Lipperts site I see the 5/8” on slides where the mechanism is located under the slide in the basement. I don’t see it on this slide. Starting to rain here so I’m on standby. Thanks for your input. Mine has one under the bed floor. I even drilled a hole in the bulkhead so I could get the socket on it without removing the panel above the motor / gearbox. Link to comment Share on other sites More sharing options...
Capt Mike Posted April 12, 2023 Author Share Posted April 12, 2023 Thanks 96 EVO, I’m going to have a closer look, it “seems” like I have everything exposed. Hopefully the rain will let up and I’m giving my back a rest too 🤷♂️ Link to comment Share on other sites More sharing options...
Solution 96 EVO Posted April 12, 2023 Solution Share Posted April 12, 2023 If you have one, it should be facing the bulkhead where your storage area is, under the foot of the bed. Link to comment Share on other sites More sharing options...
Capt Mike Posted April 12, 2023 Author Share Posted April 12, 2023 I’ll have a closer look in a little bit. Thanks, this group is simply awesome. Link to comment Share on other sites More sharing options...
Capt Mike Posted April 13, 2023 Author Share Posted April 13, 2023 96 EVO! I found it after taking most of the mechanism apart! And I fully understand what you did. I’m going to drill the access hole like you did. Thanks so much. Link to comment Share on other sites More sharing options...
96 EVO Posted April 14, 2023 Share Posted April 14, 2023 Great! Keep in mind, as your slide retracts, the motor / gearbox doesn't, so you will need to add more extensions to your ratchet. Link to comment Share on other sites More sharing options...
Happycarz Posted April 14, 2023 Share Posted April 14, 2023 1 Link to comment Share on other sites More sharing options...
Happycarz Posted April 14, 2023 Share Posted April 14, 2023 I drilled a 2” hole so I could use one of those caps for running computer cords through a desk. I finished with a descriptive yellow label. Link to comment Share on other sites More sharing options...
96 EVO Posted April 14, 2023 Share Posted April 14, 2023 4 hours ago, Happycarz said: I drilled a 2” hole so I could use one of those caps for running computer cords through a desk. I finished with a descriptive yellow label. I went fancier! A strip of masking tape with 5/8" written on it 😁! Link to comment Share on other sites More sharing options...
