rustykramermetalfab Posted April 28, 2023 Share Posted April 28, 2023 I was leaving a campground early this morning and my Park brake indicator light would not go out. I verified with a slightly unlevel site that the coach would roll in neutral when I let off of the brake pedal. Indicator flashes when driving. Coach seams normal in every way. I am not sure where the sensor is I just got parked for the night but wanted to message the group about it. 2006 Dynasty. Thanks! Link to comment Share on other sites More sharing options...
Ivan K Posted April 29, 2023 Share Posted April 29, 2023 Yours being the same year as ours and me having the same issue when we bought the coach, you probably have a failed 65psi pressure switch hanging off the park brake plunger line, just under it. Ours was Merritor Wabco 89404 16062. But it could be any equivalent with the same 1/8 -27 thread and pressure rating, normally closed. Link to comment Share on other sites More sharing options...
rustykramermetalfab Posted April 29, 2023 Author Share Posted April 29, 2023 2 minutes ago, Ivan K said: Yours being the same year as ours and me having the same issue when we bought the coach, you probably have a failed 65psi pressure switch hanging off the park brake plunger line, just under it. Ours was Merritor Wabco 89404 16062. But it could be any equivalent with the same 1/8 -27 thread and pressure rating, normally closed. Ivan Thanks I will check it when I can, I guess it is no big deal. Black tape for now! Link to comment Share on other sites More sharing options...
