weighman695 Posted June 20, 2023 Share Posted June 20, 2023 Hello, There is a slow leak on my Shorelines Hose Reel CW40D. Attached are pictures of the location of the leak. Anybody had this problem before? How did you resolve the leak problem. Do I need to replace the brass fitting that is identified by a red arrow in the attached picture? If so, how? Where did you buy the required parts to be replaced? Do I need to remove the wet bay front panel to access the hose reel to replace the parts? I can reach the hose reel from the pump room but it is really tight. Any help on what direction I should be looking at is highly appreciated. Thanks you.... Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted June 20, 2023 Share Posted June 20, 2023 Earnel, this is what I did to make access to the bay easier. I got tired of disconnecting and removing the panel. I also got a little more storage space in the upper righthand corner. My house reel was leaking too. It is fastened to the "ceiling" and I haven't tried to remove it as it looks like a too tough of a job. Maybe someday. I also moved my water pump up front for access. It was too far back in the corner when maintenance was needed. My first photo installation. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
