Bart Hansen Posted July 6, 2023 Share Posted July 6, 2023 Hello, I have a 2007 Monaco Diplomat, and I have lost power to the Tecma toilet. I disconnected the power to it, and hooked it directly to a battery, and the toilet works again. my owners manual says that it is a 40 amp mini breaker located in the outside battery compartment in a black box located near the on top. I located the box, but there is no 40 amp main breaker. I see no in-line fuse near the rear of the toilet either. Also, there is no fuse for the toilet on my panel in the closet, nor in the outer fuse panel compartment under the driver’s seat. I have to think that this is a fuse/breaker issue, but I am having no luck. Any suggestions would be greatly appreciated. thank you. Link to comment Share on other sites More sharing options...
Paul Ar Posted July 8, 2023 Share Posted July 8, 2023 Did not see your post here yesterday. Hope the new wiring goes well - very frustrating situation. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 8, 2023 Share Posted July 8, 2023 Did you probe every fuse to make sure ALL were good? Monaco did some strange stuff at times one of which was to not label the fuses correctly or even piggyback item's together on the same fuse labeling it something else. Link to comment Share on other sites More sharing options...
