Cajunboy1959 Posted July 16, 2023 Share Posted July 16, 2023 Good morning Monacoers, I'm new to this. I've had my Safari Cheetah 38PDQ for 3 months. I have 4 electric power glide slides. The front two and the drivers side read go in and out when I use the switches at control panel. My rear passenger slide works both manually and when I apply 12volts. On the in out switches there are 3 positions middle supplies 12 volts and the other two pins are for in and out. My issue is on my rear passenger switch there seams to be a short. With a continuity meter both wires show short to ground. I have found the relay board and all relays but one tested good. I put a new one in. Same thing short on two wires. I have the 12volts on center pin but when I operate in or out even with motor unplugged it still blows the fuse on the relay board. Can any one tell me if there is another board besides the ones in the pictures. I'm trying to run 2 new wires for the switch but I cannot figure out where these two wires go to. Does the relay board in the pictures control all 4 slides or just the three that are working? Any help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 16, 2023 Share Posted July 16, 2023 4 hours ago, Cajunboy1959 said: Good morning Monacoers, I'm new to this. I've had my Safari Cheetah 38PDQ for 3 months. I have 4 electric power glide slides. The front two and the drivers side read go in and out when I use the switches at control panel. My rear passenger slide works both manually and when I apply 12volts. On the in out switches there are 3 positions middle supplies 12 volts and the other two pins are for in and out. My issue is on my rear passenger switch there seams to be a short. With a continuity meter both wires show short to ground. I have found the relay board and all relays but one tested good. I put a new one in. Same thing short on two wires. I have the 12volts on center pin but when I operate in or out even with motor unplugged it still blows the fuse on the relay board. Can any one tell me if there is another board besides the ones in the pictures. I'm trying to run 2 new wires for the switch but I cannot figure out where these two wires go to. Does the relay board in the pictures control all 4 slides or just the three that are working? Any help would be appreciated. Thanks Are there prints in your manual. Take a photo and post Link to comment Share on other sites More sharing options...
Cajunboy1959 Posted July 21, 2023 Author Share Posted July 21, 2023 Hi Tom, These are the 3 prints of the 12 volt systems in my 2004 Safari Cheetah PDQ. I have 4 slides. Thanks, Gary I hope these help Link to comment Share on other sites More sharing options...
