daveyjo Posted August 21, 2023 Share Posted August 21, 2023 Where are the pressure ports/ freon fill ports on a 2005 38' Holiday Rambler Scepter? Link to comment Share on other sites More sharing options...
CAT Stephen Posted August 21, 2023 Share Posted August 21, 2023 3 minutes ago, daveyjo said: Where are the pressure ports/ freon fill ports on a 2005 38' Holiday Rambler Scepter? The R134a low and high pressure ports of located in the area on the front of your coach on the upper left from the generator when your generator access cover is opened. You will also find additional ports in the rear of the coach near the A/C compressor. Just follow the refrigerant lines. Link to comment Share on other sites More sharing options...
DavidL Posted August 21, 2023 Share Posted August 21, 2023 Like Stephen K states....but...the "upper left"...is this looking at the front ie: passenger side? That is more typical since AC evaporator is normally on passenger side on most RVs. Link to comment Share on other sites More sharing options...
