Guest terry05dip Posted June 23, 2020 Share Posted June 23, 2020 Does anyone have in there scrap pile a Carefree of Colorado Power Visor? Mine broke free while driving down the road. That will wake you up. Looking for the 2 end mounts for a QF040MA24L. This is a 40 in long with a 24 in drop, left side motor visor. My visor still work fine just broken mounting brackets. Exhausted all sources. Carefree no longer manufactures. Thank you Link to comment Share on other sites More sharing options...
Bob Priest Posted June 23, 2020 Share Posted June 23, 2020 DO YOU HAVE PICTURES OF WHAT YOU ARE LOOKING FOR? IF DO SEND THEM TO ME BPRIEST@BHPPLUMBINGHEATING .COM AND I WILL SEE IF I HAVE WHAT YOU NEEDED THANKS BOB PRIEST Link to comment Share on other sites More sharing options...
Tom Rosenbaum Posted June 23, 2020 Share Posted June 23, 2020 1 purchased two plastic mounting brackets used for gutters. They are still holding up the visor after 10 years. You can't see them from the inside or out. Link to comment Share on other sites More sharing options...
saflyer Posted June 24, 2020 Share Posted June 24, 2020 (edited) 20 hours ago, terry05dip said: Does anyone have in there scrap pile a Carefree of Colorado Power Visor? Mine broke free while driving down the road. That will wake you up. Looking for the 2 end mounts for a QF040MA24L. This is a 40 in long with a 24 in drop, left side motor visor. My visor still work fine just broken mounting brackets. Exhausted all sources. Carefree no longer manufactures. Thank you Eventually this happens to everyone. The end pieces will break and CareFree’s answer is throw away what is otherwise a perfectly good shade and replace it with a new, very expensive one. I think this would be the classic project for someone with a 3D scanner and printer. Take a set of unbroken shades and make copies of the end pieces. Make a few at a time for pennies, no need for a big production run. Like I said, we’ll all need them eventually. There are plenty of other parts 3D printers are perfect for. Ed ’05 HR Ambassador Edited June 24, 2020 by saflyer Link to comment Share on other sites More sharing options...
jreich888 Posted June 24, 2020 Share Posted June 24, 2020 I ended up using metal pipe strapping, and shaped and bent it around the end of the shade. Spray painted it black and screwed into the header with better quality pan head screws. It's held up for 4 years so far. Jason. Link to comment Share on other sites More sharing options...
Luther Taylor Posted June 24, 2020 Share Posted June 24, 2020 Give Colaws in Carthage , Missouri a call. 877-548-2125 they salvage RVs Good luck. Link to comment Share on other sites More sharing options...
coastal_front Posted June 25, 2020 Share Posted June 25, 2020 I had exactly the same thing happen when the plastic mounting bracket broke - on a mountain road. I couldn't find a part that would work and fixed it with a tough piece of plastic strapping used to hang pipes. I mounted it around the the shade mechanism using the screws that were there. Works fine so far. Link to comment Share on other sites More sharing options...
