jegall Posted August 26, 2023 Share Posted August 26, 2023 2003 HR Imperial all storage doors work ok but entry door will unlock but not lock replaced key pad no change looking for wiring diagram for door lock solenoid? Link to comment Share on other sites More sharing options...
ok-rver Posted August 26, 2023 Share Posted August 26, 2023 My Scepter 2004 had a two contact pad on the coach hinged side of the door and probes in the door that made the connection. You might use a multimeter on the coach contacts and see if you are getting 12vdc when the keypad is activated for lock and unlock. I believe that the voltage is reversed between lock and unlock. Link to comment Share on other sites More sharing options...
