terboggs Posted August 31 Share Posted August 31 Just got back from boondocking, need to drian the stored water, where is the drain value for a 2001 Monoco Executive Link to comment Share on other sites More sharing options...
Dr4Film Posted August 31 Share Posted August 31 Find your fresh water tank, then look under the coach for a drain hose. Then follow the hose up into the bottom of the coach and you should see the drain valve fairly near the same area. Unless they decided to place the drain valve in a remote location far away from the fresh water tank, then it's any ones guess. 1 Link to comment Share on other sites More sharing options...
Paul J A Posted September 1 Share Posted September 1 Why? Link to comment Share on other sites More sharing options...
Craggar Posted September 1 Share Posted September 1 Did you look in you're wet bay? That's where mine is on my Windsor. Link to comment Share on other sites More sharing options...
