Clearance light relay 8K5 on 2004 Monaco Dynasty Diamond 4
Go to solution Solved by Dr4Film,
Csn anyone direct me to the location of the clearance light relay 8K5 on my 2004 Monaco Dynasty Diamond 4 ?? I have the electrical schematic but it does not give component location. I have intermittent clearance lights and want to monitor the relay output. Thanks in advance.
That was the first place I looked and I did not find it there, but upon reading your reply, I looked again using a flashlight and threre it was..soldered onto a board. I interpreted the electrical schematic drawing as a seperate relay. Thanks for your guidance. The relay contacts must be burned a bit, as gently tapping the relay causes the clearance lights to flicker.
