zmotorsports Posted January 2 Share Posted January 2 While digging through some past posts on another forum I also ran across the rebuild with pictures of the Meritor/Wabco purge valve rebuild. With the air drier so hard to access on these S-Series chassis, I figured while I had the left rear tag tire/wheel off replacing air springs, I would rebuild the purge valve. It hasn’t given me any issues but over time they can begin to build up deposits in the valve itself and then not seal completely resulting in an air leak. With 130k miles on the coach I opted to tear it apart, clean it and reassemble with new software components. The Wabco/Meritor kit that I purchased came with all of the internals so in they went. It was due as there was some buildup just waiting to cause an air leak. Nothing too awfully bad though, just enough that I feel good about my decision to rebuild it. New parts in the background, old in the foreground. I’ve seen people leave these steel washers out by mistake but it’s important to put them in place to keep the steel spring from gouging into and wearing the brass valve as well as the plastic cone. One steel washer goes into the seat of the plastic diffuser cone. I put a little of the supplied grease on the washer which helps hold things together during assembly. The other steel washer goes on the brass valve, again using some grease to hold everything together plus lube then new o-rings and seal. One o-ring on either side of the steel seat before installing and the grease helps hold things in place. Usually if doing this on the bench it’s not so important but I didn’t feel like removing the entire air drier to just rebuild the purge valve so I’ll be inserting the parts up into the drier and fighting gravity. Parts greased up and installed into position. Now comes the fun part and the hardest part when doing this on the coach. The plastic diffuser end has to go in place and you must compress the spring enough to install the heavy snap-ring into place. If your lucky enough to have three hands you’re all set otherwise you have to devise a plan to push the diffuser up into the bore far enough to then install the snap ring and the spring is fairly stiff. I grabbed a piece of steel tubing approx. 2’ long that just fit around the reduced section of the diffuser. Then grabbed my floor jack and positioned it directly below the purge valve. I raised the floor jack GENTLY and just enough to push the plastic diffuser into place. Be sure to put the snap ring over the tubing prior to using the floor jack. Then simply use a pair of snap ring pliers to compress and put into place. Easy peasy. Purge valve rebuild complete. Thanks for looking and hope this information is helpful. 1 Link to comment Share on other sites More sharing options...
tmw188 Posted January 2 Share Posted January 2 Thanks Mike for that info with pictures. 1 Link to comment Share on other sites More sharing options...
Jdw12345 Posted January 3 Share Posted January 3 Nice work Mike, glad to see you use Wabco/Meritor genuine parts. I was also in the trucking business for all my life, when it comes to the air dryer I use only genuine parts. After purchasing our coach 2 1/2 years ago servicing the air dryer was one of the first things I serviced. For those looking to service there air dryer here’s a link that you might want, https://www.wabco-customercentre.com/catalog/docs/mm34_web.pdf 2 Link to comment Share on other sites More sharing options...
zmotorsports Posted January 3 Author Share Posted January 3 21 hours ago, tmw188 said: Thanks Mike for that info with pictures. You're welcome. 15 hours ago, Jdw12345 said: Nice work Mike, glad to see you use Wabco/Meritor genuine parts. I was also in the trucking business for all my life, when it comes to the air dryer I use only genuine parts. After purchasing our coach 2 1/2 years ago servicing the air dryer was one of the first things I serviced. For those looking to service there air dryer here’s a link that you might want, https://www.wabco-customercentre.com/catalog/docs/mm34_web.pdf Agreed. There are certain things that I insist on using only OEM parts and these air dryers are one of them. Link to comment Share on other sites More sharing options...
