Newcsn Posted March 12 Share Posted March 12 The footrest on our passenger captains chair stopped working. Originally I thought the motor was bad. Took it apart & found that the motor works fine - but - the plastic gear that the worm gear travels through is cracked & bound in the metal housing. Wondering if anyone’s run across this issue & if the plastic part is available anywhere? Yes, Villa International says they can sell me the whole motor but would prefer not to drop ~$100. Thank You! Link to comment Share on other sites More sharing options...
klcdenver Posted March 12 Share Posted March 12 Someone with a 3D Printer could possibly make it for you. Link to comment Share on other sites More sharing options...
Marine Boy Posted March 12 Share Posted March 12 FYI - Did the same repair about a year ago and at the time I was told by Villa that the parts for these vintage seats are all old stock and once they are all sold they will not be made again. The person I talked to had been there a while and seemed very knowledgeable. Link to comment Share on other sites More sharing options...
Gary M Posted March 12 Share Posted March 12 2 hours ago, Newcsn said: The footrest on our passenger captains chair stopped working. Originally I thought the motor was bad. Took it apart & found that the motor works fine - but - the plastic gear that the worm gear travels through is cracked & bound in the metal housing. Wondering if anyone’s run across this issue & if the plastic part is available anywhere? Yes, Villa International says they can sell me the whole motor but would prefer not to drop ~$100. Thank You! You might call Lise Bauer who worked for Flexsteel (if yours are Flexsteel’s) and may know a source. Link to comment Share on other sites More sharing options...
Martinvz Posted March 12 Share Posted March 12 Do you know of a machine shop that could make one for you using the old one as template? It can be nylon and not steel. I am not sure if the normal 3D printing material will be strong enough. Link to comment Share on other sites More sharing options...
Bob Keating Posted March 13 Share Posted March 13 I had a similar issue, but was able to cobble mine back together, however, it was not split like yours. In looking for a solution, I found this (P/N 2224N17) in the McMasters & Carr catalog. You might be able to modify it to fit your use. 2 Link to comment Share on other sites More sharing options...
Newcsn Posted March 14 Author Share Posted March 14 Thanks for all the input! Decided to buy a small hose clamp & see if I could tighten it around the cracked plastic gear & reinsert it in the metal bracket. Well, it appears we have a solution - and - for less than $2.00! The footrest raises & lowers with no binding and the end of the hose clamp actually acts as an additional brace against the metal housing. As they say, “Even a blind squirrel finds a nut every once in a while!” 4 Link to comment Share on other sites More sharing options...
