Dynasty Posted March 22 Share Posted March 22 Friends. I live in Norway, own a Monaco Dynasty 40' 2005 S chassis. I am in need of trailing arm bushings and tag axle repair kit between brake bilg and slack adjusters ( fork, bushing and pin). Can anybody help with part numbers and suppliers? Thor-Steinar Christensen. Bergen, Norway Monaco Dynasty Bishop III 2005 Cummins ISL 400 Link to comment Share on other sites More sharing options...
jacwjames Posted March 22 Share Posted March 22 Here is a link to a trailing arm bushing, not sure if they ship overseas. https://shop.findmyrvparts.com/searchresults.asp?Search=bushing&Submit= In the downloads section there is a parts list that has a lot of different info, you find you tag axle parts there. Do you know the manufacturer of the rear/tag axle, most parts are common to large trucks. From my understanding Monaco bought the axles as an assembly and mounted them to the chassis. There should be a tag on the axle which might give you enough info to hunt down a parts breakdown. Link to comment Share on other sites More sharing options...
Paul J A Posted March 22 Share Posted March 22 (edited) Hi. I have been to your beautiful city many times. Look for a metal tag on the axle. It will have the information you need to order the parts. I would try; https://sourcerv.com/ Scott or Jim. The are engineers and worked at Monaco when your coach was built. They know the Roadmaster chassis better than anyone in the USA. Another is; https://josamusa.com/ Another is; https://www.hendersonslineup.com/ Edited March 22 by Paul J A Link to comment Share on other sites More sharing options...
