mandms59 Posted July 16, 2020 Share Posted July 16, 2020 All, Please see photos - I could not find any reference in the owners manuals I have to these pair of holes located at front of coach just in front of both Driver & Pax slide-outs (same height and in alignment). It almost looks like they would support a spring loaded collapsible rod ?? there is a small metal pin/rod in center at both ocations. Thanks for assistance in advance. Link to comment Share on other sites More sharing options...
Stinger Posted July 16, 2020 Share Posted July 16, 2020 (edited) 38 minutes ago, mandms59 said: All, Please see photos - I could not find any reference in the owners manuals I have to these pair of holes located at front of coach just in front of both Driver & Pax slide-outs (same height and in alignment). It almost looks like they would support a spring loaded collapsible rod ?? there is a small metal pin/rod in center at both ocations. Thanks for assistance in advance. Mark; those are exactly like our '07 HR Endeavor's holes. They are for inserting the stabilizer rods between the wall and the inner panel of the slide-outs. Purpose would be to prevent the slides from ever coming out during travel. I have not used them but I'm sure others probably have. Knowing me, I'd forget to remove them after travel before trying to put the slides out!! Those rods are normally stored in the basement area. Edited July 16, 2020 by Stinger Link to comment Share on other sites More sharing options...
Joel Sheriff Posted July 16, 2020 Share Posted July 16, 2020 (edited) They are for the support rod that locks the slide out shutting travel. You should have two adjusting poles to fit into slot and pad to sit on slide out when closed inside.  Edited July 16, 2020 by Joel Sheriff Upload pix Link to comment Share on other sites More sharing options...
Dwight Lindsey Posted July 16, 2020 Share Posted July 16, 2020 Here's what the slide locks look like: https://www.rvpartscountry.com/RV-Slide-Lock.html?gclid=EAIaIQobChMIg4648_XQ6gIVEiCtBh0x4Q7XEAQYBSABEgJnQvD_BwE They are different lengths for the two slides, so if you don't have them , be sure to get the right lengths. Dwight 1 Link to comment Share on other sites More sharing options...
mandms59 Posted July 16, 2020 Author Share Posted July 16, 2020 All, Thank you for the information... as I am the 3rd owner of coach (since 10/19), there were no slide locks in basement or inside MH when I purchased it on consignment. Dealer did not mention anything about them during walk thru. They may have disappeared with the original owner; sent a note to second owner to see if they ever had them.... in previous discussions the slide locks were not mentioned. R/ Mark Link to comment Share on other sites More sharing options...
glang11082 Posted July 17, 2020 Share Posted July 17, 2020 On 7/16/2020 at 11:18 AM, mandms59 said: All, Thank you for the information... as I am the 3rd owner of coach (since 10/19), there were no slide locks in basement or inside MH when I purchased it on consignment. Dealer did not mention anything about them during walk thru. They may have disappeared with the original owner; sent a note to second owner to see if they ever had them.... in previous discussions the slide locks were not mentioned. R/ Mark I found mine under the bed. Have never used them. Link to comment Share on other sites More sharing options...
