Kenster Posted March 23 Share Posted March 23 (edited) Does anyone know where they have hidden the control module for the Carefree awning on the 06 Diplomat? They are typically located in the front Bay passenger side, but not on mine. I have located the relays behind the switch panel on the passenger side Dash, but that's not what I'm looking for. I'm looking for the actual control module itself. 3 hours later, I'm starting to believe there may not be a control box and everything may be ran through the switch and relay. Edited March 24 by Kenster Link to comment Share on other sites More sharing options...
Happycarz Posted March 27 Share Posted March 27 Ken, stop looking! You have only what is located behind the switch panel. If you had a wind sensor you would have a module, but the Carfree Eclipse has only what you have found. Mine is same way. Link to comment Share on other sites More sharing options...
Kenster Posted March 27 Author Share Posted March 27 I figured that out. Thank you very much for your response. It appears I have an intermittent solid state relay. For the time being I have constructed a couple jumpers that allow me to manually override the solid state relay if necessary, until I can get to civilization and get what I need replace the solid state relay with dry contacts. Link to comment Share on other sites More sharing options...
Happycarz Posted March 27 Share Posted March 27 If you don’t need the outside switch on the bottom of the awning arm, you can eliminate the SS cube relay and wire it directly from switch to motor. Link to comment Share on other sites More sharing options...
Kenster Posted March 31 Author Share Posted March 31 Thank you. Link to comment Share on other sites More sharing options...
