Kenster Posted March 29 Share Posted March 29 Any thoughts on Switching original Green coolant to Red final charge in isl400 with 150k on it. Link to comment Share on other sites More sharing options...
joefromperry Posted March 29 Share Posted March 29 That's exactly what I did when I replaced my radiator on my 2003 Signature with ISX 525 a few years ago. Make sure you change coolant filters to one without chemicals. I used a Napa 4113, but yours is probably different. Link to comment Share on other sites More sharing options...
Benjamin Posted March 29 Share Posted March 29 That seems to be what everybody is doing. If you want to be thorough, drain the coolant, fill it with rainwater or distilled water, drive it several minutes or hours, drain the water and see how much sediment settles into the bottom of the container. If there's too much, repeat. If good, fill with a couple gallons of concentrate at least to mix with the left over water. The differences between the old SCA coolant and the new OAT type is OAT is easier on aluminum and provides longer protection, and SCA is easier on copper radiators and protects better while it is maintained. Link to comment Share on other sites More sharing options...
Bar SR Ranch Posted March 31 Share Posted March 31 Here is a link to the Fleetguard coolant webinar training video from February 2024. Well worth the 1 hour of time. Being a heavy equipment mechanic for 40 plus years I still learned and had several questions answered. FYI they just had one on oil and filtration, also worth the time. Training | Fleetguard Link to comment Share on other sites More sharing options...
Kenster Posted March 31 Author Share Posted March 31 Thank you. Link to comment Share on other sites More sharing options...
