mik_kan Posted April 10 Share Posted April 10 I have a 2004 Holiday Rambler Admiral and do not have any 12v power to my panel. The slides work, the converter is putting out 13.6v, and the batteries are fully charged. Tested the cutoff switch and the fuse and everything is working. I have tested it being connected to shore power and battery power. I need help, I can not figure out what it can be. Thanks Link to comment Share on other sites More sharing options...
jacwjames Posted April 10 Share Posted April 10 Do you have a switch near the front door that shuts off the house power, which is the fuse panel that feeds lights, and most of the 12 volt power in the house. The switch turns on/off a relay. Link to comment Share on other sites More sharing options...
Rocketman3 Posted April 10 Share Posted April 10 Post a picture of your rear electrical bay. That often helps Link to comment Share on other sites More sharing options...
mik_kan Posted April 10 Author Share Posted April 10 (edited) The house cutoff switch is by the batteries and I tested both sides of the switch. Rear electrical bay has the cutoff switch, a fuse and 2 wires that comes out of the panel in the bay. Edited April 10 by mik_kan Link to comment Share on other sites More sharing options...
mik_kan Posted April 12 Author Share Posted April 12 I found the problem it was the Battery Disconnect Switch. Thanks for your help. Link to comment Share on other sites More sharing options...
