Keith H. Posted April 12 Share Posted April 12 In my 2003 Signature Centurion, I have two fuse boxes outside (in engine bay & street side in front of front tire). I have an inside fuse box in my closet and I have 2 breaker boxes in my bedroom. The two outside fuse boxes have multiple and sometimes a whole banks or sets of fuses with red lights on. I checked the fuses and they are all good. This does not happen when the generator is on. It only happens if the engine is running. I have NOT checked with both the generator running and the engine on. Nor have I tried it with shore power. Is this normal and if not what would cause this? Link to comment Share on other sites More sharing options...
Frank McElroy Posted April 12 Share Posted April 12 Those are indicator LED lights that are only powered when the ignition key is on. The color means nothing special. Monaco used alternating colors to make it a bit easier to see which LED went with which description and to add to the "WOW" factor when opening up those boxes. For someone troubleshooting a circuit, the LEDs would show if the circuit and switches inside the coach are working without needing a voltmeter. If the LED is lit, the fuse is good and circuit is getting power. Same for when a switch is activated, a LED light will come on showing that the switch is being pressed. If a relay is supposed to energize, there will be a LED light on the relay coil and another LED on the output wire. So if you know how to read a schematic, you can troubleshoot a circuit by just looking at which LEDs light up. All those LEDs are shown in the wiring diagram board schematics. Link to comment Share on other sites More sharing options...
Keith H. Posted April 12 Author Share Posted April 12 Whew!!! I never noticed. I started looking for my fog light fuse (which I found) because they did not work. When I opened the fuse bay door, I thought it was Christmas! Everything was working (except lights and steps) but no fuses were blown. I thought something serious was wrong. Well now to get my fog lights and Kwikee steps project. At least its not a fuse! Link to comment Share on other sites More sharing options...
Frank McElroy Posted April 12 Share Posted April 12 You're not the first to be surprised by all those lights. Often when trying to help someone troubleshoot a problem, I'll ask them to take a picture (with the ignition ON) of a certain board as they press and release a switch inside the coach. That pretty much would tell me what has failed without voltage readings. I'm glad those Intellitec boards were basically designed with self diagnostic LEDs on them. Link to comment Share on other sites More sharing options...
