NAMVET77 Posted April 19 Share Posted April 19 My 04 Camelot has developed a water leak where the connection coming from the reel to the pex tubing is. Took the reel out and removed the fitting (quick disconnect) from the reel. There is one oring on that quick disconnect. Reading through other sites some have mentioned replacing 2 or 3 orings. Anyone have experience with replacing the orings (how many)? The reel is a TDI product (can't find any info on them) part number RVW5003. Thanks. Don PS. Still working on figuring why my emergency brake won't relaese. Link to comment Share on other sites More sharing options...
Solution NAMVET77 Posted April 20 Author Solution Share Posted April 20 Just a follow up. I replaced the O ring on the quick disconnect, lubed it, greased the plastic ring and put it back together. Now everything seems to be working fine. At least for now there are no leaks. Don Link to comment Share on other sites More sharing options...
