JimC295 Posted April 22 Share Posted April 22 I just want to give a shout out to Weller truck parts and to post the contact who is currently handling the Shepard to TRW gear box swap. Weller was awesome to deal with, I first emailed John Vanlaan who said he no longer handles the swap info but set me up with Nick Vangeest (Nick Vangeest nvangeest@wellertruck.com ) it was plug and play after that. Nick even offered to send one of their trucks to pickup the core. If you are contemplating the swap Weller is a great place to assist you in this endeavor. I am including a copy of Johns 1st email with Nicks name. Good Morning Jim, Thanks for reaching out to us. You have come to the right place. I am no longer in the Steering Department, however, I am still with the company and happy to point you in the right direction. We have sold many of the TRW replacement gears. They are not quite a bolt on and go replacement, however, a lot of RV owners have made the swap and are extremely happy with the change. The TRW gear you will need is the TAS65 052 and the NEW Pitman arm that will be needed for the swap too is 84242502. I have included some instructions from the forum (These instructions are older and we have sense updated which TRW gears and Arm works best but they are the same concept and should help you or your mechanic doing the swap). I have also included the Steering Department and counter sales Nick Vangeest who can better help you with questions, pricing, and shipping. Hope this is what you are looking for and can help make your Monaco Coach more enjoyable for you. John 3 Link to comment Share on other sites More sharing options...
tmw188 Posted June 8 Share Posted June 8 Well do you like it? Link to comment Share on other sites More sharing options...
JimC295 Posted June 9 Author Share Posted June 9 Todd after some learning issues and hiccups cause by me absolutely yes. I was ready to pass this coach on to someone else to deal with, but the loose steering issue has been solved/fixed. 2 Link to comment Share on other sites More sharing options...
JimC295 Posted June 9 Author Share Posted June 9 I cannot emphasize enough correct torque on the gear box. I had a friend helping me install the gearbox. When we put the bolts in he hammered them down and said thats good. I did have doubts about them being tight enough because I did not have a good high end pneumatic impact. So on our return from my last trip, I rounded a corner in traffic side by side with several semis and it was not turning with the correct amount of input I had to keep turning to get it around the corner. It was scary so the next rest stop I pulled in and had my wife turn the wheel as I watched the gear box. It was moving around every time she turned the wheel, so the next exit I pulled into a truck stop and they hammered it down and now all is well. I am thinking I am going to buy some new bolts and lock nuts and replace them one at a time. I also purchased a high torque Ridgid 18v impact wrench so if the issue reoccurs, I am prepared to fix the problem. 1 Link to comment Share on other sites More sharing options...
dl_racing427 Posted June 10 Share Posted June 10 17 hours ago, JimC295 said: I cannot emphasize enough correct torque on the gear box. I had a friend helping me install the gearbox. When we put the bolts in he hammered them down and said thats good. I did have doubts about them being tight enough because I did not have a good high end pneumatic impact. So on our return from my last trip, I rounded a corner in traffic side by side with several semis and it was not turning with the correct amount of input I had to keep turning to get it around the corner. It was scary so the next rest stop I pulled in and had my wife turn the wheel as I watched the gear box. It was moving around every time she turned the wheel, so the next exit I pulled into a truck stop and they hammered it down and now all is well. I am thinking I am going to buy some new bolts and lock nuts and replace them one at a time. I also purchased a high torque Ridgid 18v impact wrench so if the issue reoccurs, I am prepared to fix the problem. Definitely, ALWAYS properly torque fasteners, especially those related to the steering, suspension or brake systems. Glad you're unhurt and no real damage so far. Replacing those fasteners is a good idea. Loose fasteners can easily be overstressed. Link to comment Share on other sites More sharing options...
Benjamin Posted June 10 Share Posted June 10 I'm sure you know, but check the grade of the bolts by the markings on the head, and replace with the same grade. If you can't find a torque spec, then use a generic torque spec based on the bolt thread size and grade. 2 Link to comment Share on other sites More sharing options...
