monacodynasty05 Posted May 24 Share Posted May 24 Does anyone have a diagram of the air dump system. The air dump switch needed replacing and now nothing happens when it is engaged. Thank you in advance 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 25 Share Posted May 25 Sounds like you may have the optional HWH Air/Hydraulic Leveling System, is that true or not? 1 Link to comment Share on other sites More sharing options...
johncvandoren@gmail.com Posted May 26 Share Posted May 26 On 5/24/2024 at 4:56 AM, monacodynasty05 said: Does anyone have a diagram of the air dump system. The air dump switch needed replacing and now nothing happens when it is engaged. Thank you in advance Who replaced the switch (and why, if it was working before)? Did they not test it? Link to comment Share on other sites More sharing options...
monacodynasty05 Posted May 26 Author Share Posted May 26 The switch was frozen and would not operate. I purchased one from northwest supply to replace it I was trying to figure out where the valves or solenoids that control the dump are Maybe someone could explain if I can use a jumper wire and which wires on the switch to jump to further troubleshoot I don't have air leveling just rva jack system 1 Link to comment Share on other sites More sharing options...
