darrenclegg@comcast.net Posted June 8 Share Posted June 8 No 12vdc power to slider controller 2003 holiday rambler 40 pst Link to comment Share on other sites More sharing options...
Dr4Film Posted June 8 Share Posted June 8 Should we assume that all of your slides are 12 VDC electric motor driven versus hydraulic driven slides? Also, is this the ONLY device with no 12 VDC to it or do you have multiple devices with no 12 VDC? If it is the ONLY one, then get out your wiring diagrams (downloadable from this site) and look for a possible fuse that may have blown. Link to comment Share on other sites More sharing options...
darrenclegg@comcast.net Posted June 8 Author Share Posted June 8 yes, the slides are all 12vdc Link to comment Share on other sites More sharing options...
Solution darrenclegg@comcast.net Posted June 8 Author Solution Share Posted June 8 thank you all, leaving on Sunday for vacation, i added a 40 amp resettable fuse to the copper buss bar in the battery compartment. From there ran a 10 gauge wire to the red/black 12 vdc power wire from the "slide out breaker" that I could not locate. I was never able to locate a wire diagram. all fuses were checked and good Link to comment Share on other sites More sharing options...
