directorsusa Posted August 24, 2020 Share Posted August 24, 2020 Hey all. My Tv lift and TV have no power. Breakers are all good and reset. Checked voltage on safety outlet above drivers seat - all good. Seams to be between there and tv. Anything else i am missing that would kill power to this? Thanks, Jarred A. 04 HR Navigator Link to comment Share on other sites More sharing options...
David Pratt Posted August 25, 2020 Share Posted August 25, 2020 Jarred The control module for the TV LIft is located inside the Lift on the left side. The lift will have to be down to access it. Hopeful you have the manual. There should be a reset button on the module. I believe that TrI-Metal Corp was the manufacturer. You can try Googling them for information The part number for the lift is 62427. Maybe a member might have a manual and can help you out. Link to comment Share on other sites More sharing options...
