stenderken Posted September 3, 2020 Share Posted September 3, 2020 I own a 2009 Dynasty that I bought new in 2008. My dual Aqua Hot electric heating elements probably have many hundred hours of on time over the past 12 years and I am wondering if these elements ever deterioriate similar to what happens in a residential electric water heater. Has anyone ever had to replace their elements? How many years do they typically last? Is this that the technician should be checking the next time I have the Aqua Hot serviced? Link to comment Share on other sites More sharing options...
John Haggard Posted September 3, 2020 Share Posted September 3, 2020 As long as the elements work. Your good. When they quite working. Replace 1 Link to comment Share on other sites More sharing options...
96 EVO Posted September 5, 2020 Share Posted September 5, 2020 They last far longer than water heater elements due to not being in contact with the minerals that you get in tap water. Link to comment Share on other sites More sharing options...
CTerry Posted September 6, 2020 Share Posted September 6, 2020 I have a 2003 Beaver that I have replaced element once. Mine only has one. Not a hard job but you do have drain the tank down some. I'm pretty sure mine was damaged when the park we were in had some electrical problems because a lot of people with park models there lost there water heaters. They aren't going to corrode because they are in the tank fluid. Link to comment Share on other sites More sharing options...
