saflyer Posted September 9, 2020 Share Posted September 9, 2020 (edited) I plan to order some Dicor sealant for the first time. I’ve read so often advice to use it for various sealing projects. But when I looked for it on Amazon I found out there are at least two products under the Dicor name, 501LSx and 551LSx where “x” apparently designates the color. From the Dicor website it appears 501LSx is self leveling and 551LSx is not. How do I determine which I need. I’m sure it depends on the project. First up is sealing such roof items as vent covers, antenna attach points and other general items on the roof. I’m hoping for some guidance on my choice. Also, what other sealants are useful on RV’s. Can someone educate me on the subject? Ed ‘05 HR Ambassador Edited September 9, 2020 by saflyer Addition Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted September 9, 2020 Share Posted September 9, 2020 The only sealant I would use on my coach roof is eternabond, a tape type sealant. Once you put it on, it will not come off. Link to comment Share on other sites More sharing options...
saflyer Posted September 9, 2020 Author Share Posted September 9, 2020 4 hours ago, Chuck B said: The only sealant I would use on my coach roof is eternabond, a tape type sealant. Once you put it on, it will not come off. I use Eternabond but it’s not appropriate for everything. I need to know about liquid sealants. Link to comment Share on other sites More sharing options...
Ivan K Posted September 9, 2020 Share Posted September 9, 2020 I use self leveling around the roof openings, otherwise you would have to smear it around. Non leveling is good for vertical surface where you don't want it to run. Link to comment Share on other sites More sharing options...
tlpcolorado Posted September 10, 2020 Share Posted September 10, 2020 I always use the Dicor 501 on the roof penetrations and if I need to seal something like my range hood vent on vertical surface i use the 551 I have had great results with both of these and no leaks! Link to comment Share on other sites More sharing options...
