Chargerman Posted September 25, 2020 Share Posted September 25, 2020 My manual states that Dextron III is to be used for the hydraulic system. Does anyone know if using Dextron 4 is permissible? Link to comment Share on other sites More sharing options...
vito.a Posted September 25, 2020 Share Posted September 25, 2020 I replaced ours with Valvoline MaxLife synthetic. Its backwards compatible with Dexron II, Dexron III, or Dexron IV. Ours takes 50-55 quarts. https://www.walmart.com/ip/Valvoline-MaxLife-Multi-Vehicle-Automatic-Transmission-Fluid-1-Gallon/15125768?findingMethod=wpa You can save a little money going with non-synthetic. This is also compatible with Dexron II or Dexron III. https://www.walmart.com/ip/Super-Tech-Automatic-Transmission-Fluid-1-Gallon-Bottle/20573820?athcpid=20573820&athpgid=athenaItemPage&athcgid=null&athznid=PWVUB&athieid=v0&athstid=CS020&athguid=2e4c9f96-006-174c7b39b9098d&athancid=null&athena=true 2 Link to comment Share on other sites More sharing options...
Chargerman Posted September 26, 2020 Author Share Posted September 26, 2020 Thank you Vito!! Link to comment Share on other sites More sharing options...
