Robert U Posted November 23, 2020 Share Posted November 23, 2020 Have a fuel leak at the lift pump. 2 years ago tightened bolts on top and leak went away. Well it came back so I had the lift pump replaced. Turns out the lift pump was not leaking, but a fuel line was leaking near the pump. Does anybody have a diagram of fuel system on RR8 chassis ? Bob U 2000 Dip Link to comment Share on other sites More sharing options...
bobdinsmore Posted November 23, 2020 Share Posted November 23, 2020 Bob U, I also have a 2000 Diplomat that had the same lift pump problem that was corrected by tightening the bolt. It still is OK. But I'm curios why you want the fuel system diagram if your problem is fixed. Link to comment Share on other sites More sharing options...
Robert U Posted November 23, 2020 Author Share Posted November 23, 2020 The problem is not fixed only diagnosed. I want to know where the other end of the fuel hose goes. There are 6 hoses hooked to the lift pump. I am curious as to where they go. Pretty sure which one is leaking, but not positive. Bob U 2000Dip Link to comment Share on other sites More sharing options...
bobdinsmore Posted November 23, 2020 Share Posted November 23, 2020 Bob U, Thanks. I didn't realize there are so many hoses in this area. I'll keep an eye on this topic in case someone has a diagram in case I run into another problem.. Link to comment Share on other sites More sharing options...
veraken Posted November 24, 2020 Share Posted November 24, 2020 Here's what I have. Look at page 15-16. Hope it helps. 1998-2000 Monaco Chassis Schematic.pdf 1 Link to comment Share on other sites More sharing options...
Robert U Posted November 24, 2020 Author Share Posted November 24, 2020 Thank you Ken. This is exactly what I wanted. Where did you obtain the drawings ? Bob U Link to comment Share on other sites More sharing options...
veraken Posted November 24, 2020 Share Posted November 24, 2020 The older I get, the less I remember, but when I saw it, I thought it might come in handy someday. Glad I could help. Link to comment Share on other sites More sharing options...
Robert U Posted November 25, 2020 Author Share Posted November 25, 2020 Thanks a lot Ken. There is a lot of good info in that pdf. Bob U Link to comment Share on other sites More sharing options...
