ktloah Posted March 1, 2021 Posted March 1, 2021 So I'm going to be replacing my coolant in the spring and noticed a couple of rubber hoses to the radiator are questionable. Has anyone replaced these that would have z source or part # that they used? It sits on the roadmaster 10r chassis...I know I could probably remove the hose and possibly match it but would rather have it in hand before draining the system...
Chuck B 2004 Windsor Posted March 1, 2021 Posted March 1, 2021 They probably go to the transmission oil cooler. If so the cooler is a 4 inch square 3 ft long device located to the left of the lower part of the engine. The cooler device has a pipe inside it where the transmission oil flows. The pipe is surrounded with the radiator coolant. Chuck B
ktloah Posted March 1, 2021 Author Posted March 1, 2021 Hey Chuck, hose I'm thinking of is the return hose from radiator to the engine. Looks like rubber hose to the metal pipe back to metal hose back to rubber to engine. Thx for the reply
RC2018 Posted March 2, 2021 Posted March 2, 2021 I replaced mine on my 2003 Diplomat. I replaced mine with Silicone hose. The metal you are referring to between the rubber on mine has a muffler clamp welded to a strap supporting it and after jiggling it around during hose replacement it started leaking at the clamp from the rust. The rest of the metal pipe was fine but there were pin holes in the metal pipe where the clamp was attached. I had to send the metal pipes to a fab shop to duplicate, (no part number or drawing that I could find) I replaced with custom fabricated Stainless Steel pipes. The rubber hoses I took off were hard and cracked. In the end I replaced all the coolant hoses with silicone. If yo use silicone, remember they require a specific style clamp made for soft hose. 1
Twomed Posted March 2, 2021 Posted March 2, 2021 https://www.daycoproducts.com/parts?category_id=1084 Try your VIN number here...it worked for mine a couple of years ago...gave me all the hose numbers. 1
ktloah Posted March 2, 2021 Author Posted March 2, 2021 (edited) Awesome, I'll give it a try....thank you No joy on the vin #...thxs for the try Edited March 2, 2021 by ktloah
Twomed Posted March 2, 2021 Posted March 2, 2021 https://www.daycoproducts.com/parts?category_id=1136&year=2004&make=98&modeltype=26&model=3252&description=12939 They have changed it...IF you go to online catalog>Heavy Duty> fill in your requests info it will give you a list like above. Fingers crossed 😀
Steven P Posted March 3, 2021 Posted March 3, 2021 The shop that did mine had to have some custom made from a hose shop.
a4epilot Posted March 3, 2021 Posted March 3, 2021 21 hours ago, ktloah said: Awesome, I'll give it a try....thank you No joy on the vin #...thxs for the try I just tried as well. VIN didn't work; however, go the Heavy Duty Vehicle section and enter by vehicle type, Brand, etc. Found my 06 Windsor with hose and other information. Gary K
ktloah Posted March 3, 2021 Author Posted March 3, 2021 Thanks Chuck and everyone for your help. Was able to get #'s from what Chuck posted...Thanks again!!
Twomed Posted April 9, 2021 Posted April 9, 2021 Good to hear... replacing mine next week along with all the rusty pipes. I got 304 stainless tubing...no more rust. 🙂
