StillRunning_60 Posted May 1, 2021 Share Posted May 1, 2021 Went back out and took another pic of the pitman arm attached to the steering box. Not a good edge to see the attachment but hopefully someone can tell how it is attached. Link to comment Share on other sites More sharing options...
jacwjames Posted May 1, 2021 Share Posted May 1, 2021 Larry, In a previous post I attached a Service Manual for the Sheppard M100. On page 41 it explains how to remove the pitman, There is a cap that has tabs that prevent it from coming out, have to bend the tabs up and then it takes a special tool to pull the retainer. It will be very tight, I believe it specs 350 ft-lbs when reassembling. Link to comment Share on other sites More sharing options...
Bob Nodine Posted May 2, 2021 Share Posted May 2, 2021 The easy way to tell the difference between a Shepard and a TRW is often overlooked. The TRW uses a bolt thru the top of the Pitman arm clamping it to the output spline shaft. The Shepard is significantly beefier and has a nut attaching the arm to the output shaft with a locking washer. Below is a photo of the Pitman arm of a TRW. I do not have a photo handy of the Shepard but they are like night and day. Link to comment Share on other sites More sharing options...
StillRunning_60 Posted May 2, 2021 Share Posted May 2, 2021 Thanks Everyone for all your help. I will end my discussion on this by asking if anyone has 2002 36’ windsor PBD that has a TRW steering box can give be the correct part number to order from Weller. Someone a while back told me they thought I needed a TAS65 66003. Just trying to ask sure before ordering rom Weller. Thanks again. Link to comment Share on other sites More sharing options...
fredelkamp Posted May 5, 2021 Share Posted May 5, 2021 I could use the correct part number for a 2008 Diplomat 36PDQ and the name of a good installer. Link to comment Share on other sites More sharing options...
StillRunning_60 Posted May 6, 2021 Share Posted May 6, 2021 Hey Fred if you call 8774666226 or 2607289564 with your veh number they can give any info about your coach you need. I call today and got my Shepherd box number and my luck had a special pitman arm than Weller had to special built. But give than phone number a shoot. Link to comment Share on other sites More sharing options...
