John Haggard Posted April 7, 2021 Share Posted April 7, 2021 Before I remove the inside panel Any tips, suggestions 🤔 With the grandchildren traveling with us the past two weeks. The door handle has become very loose ? We do have the mid entry door Link to comment Share on other sites More sharing options...
John Haggard Posted April 7, 2021 Author Share Posted April 7, 2021 Before I remove the inside panel Any tips, suggestions 🤔 With the grandchildren traveling with us the past two weeks. The door handle has become very loose ? We do have the mid entry door Link to comment Share on other sites More sharing options...
John Haggard Posted April 7, 2021 Author Share Posted April 7, 2021 I found a spring at ace hardware that fixed the issue for now. Thank you 😊 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 7, 2021 Share Posted April 7, 2021 I think to remove the inner panel, you have to remove the window. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
John Haggard Posted April 7, 2021 Author Share Posted April 7, 2021 55 minutes ago, Gary 05 AMB DST said: I think to remove the inner panel, you have to remove the window. Gary 05 AMB DST 3 screws hold the inside latch cover. 3 end screws allow the outer handle To be removed, or adjusted. As stated above A new spring from ace hardware fixed the issue for now. I called trimark and they are sending me a new inside handle. As there is no wear and they say no adjustment for the loose handle. So after 21 years. They offered to replace as mine is defective  Link to comment Share on other sites More sharing options...
