Bob Schmeckpeper Posted May 1, 2021 Share Posted May 1, 2021 2001 Monaco Diplomat. Rivets are failing where the roof meets the sidewall. Looking for suggestions on how to fix the problems. I don't know the length of the rivets that were used. Tried 1 1/2 in long self-tapping screws which don't seem to tap into the frame. Called Monaco, no help there. Any advice would be greatly appreciated. Thanks Link to comment Share on other sites More sharing options...
Gary M Posted May 1, 2021 Share Posted May 1, 2021 Talk to Talin RV Chris Throgmartin. 352-942-2653 Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted May 1, 2021 Author Share Posted May 1, 2021 Will give them a call. Thank you. I forgot to mention that we are in the Phoenix Arizona area. Link to comment Share on other sites More sharing options...
Gary M Posted May 2, 2021 Share Posted May 2, 2021 33 minutes ago, BobSchmeck said: Will give them a call. Thank you. I forgot to mention that we are in the Phoenix Arizona area. Im in Oregon and he walked me thru what I needed to do on mine. I had to remove the clip in moulding to expose the track. Then he recommended stainless steel screws to reattach track by putting in new screws about an inch or two from the existing rivets. There is metal square tubing along the beltline. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted May 2, 2021 Share Posted May 2, 2021 I had that problem on my 05. If they used rivets, they are riveting the two fiberglass panels. There is no metal structure at that point. Those are probably aluminum rivets I couldn't see where this is happening. On mine it was the front assembly. Gary 2005 AMB DST Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted May 2, 2021 Author Share Posted May 2, 2021 Thanks for the reply. It's coming apart right behind the big slide awning & right in front of the back slide awning. Yes aluminum rivets. I can't believe that there's no prints on how the side & roof framing is made. Link to comment Share on other sites More sharing options...
Howard Posted May 2, 2021 Share Posted May 2, 2021 If yours has the aluminum roof, you should use aluminum rivets to reattach it. Steel screws or steel rivets can cause a chemical reaction with aluminum and cause the aluminum to corrode, and erode away. You might use a little larger rivet in the same home, or drill new holes close to the old ones. 1 Link to comment Share on other sites More sharing options...
Gary M Posted May 2, 2021 Share Posted May 2, 2021 Howard is correct. But I would still talk to Talin RV. 1 Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted May 2, 2021 Author Share Posted May 2, 2021 (edited) Howard Thanks for mentioning that, yes I have read that but I did not put 2 + 2 together. I was thinking stainless steel screws. Would that have the same affect as just plain steel screws? Will be calling Talin on Monday to see what I can learn. Yes I have an aluminum roof. Thanks for the input. Edited May 2, 2021 by Bob Schmeckpeper Link to comment Share on other sites More sharing options...
