Poohbear Posted June 5, 2021 Share Posted June 5, 2021 Hi everyone I have a 2004 signature and was trying to find info on the ac filter location. The coach had the decorated ceiling over where the ac is but I cant seem to see a filter or see a way to lower the ceiling fixture to get to it. So what is the deal? Link to comment Share on other sites More sharing options...
Paul Busch Posted June 5, 2021 Share Posted June 5, 2021 My 2005 sig castle has an oblong mirror detail in the living room and smalller one in the bedroom. One has 3 bolts and 2 for the other. They are under the trim detail and easily reached with a socket extension. The other side is hinged so have someone help hold it. Easy to do with help. paulb Link to comment Share on other sites More sharing options...
Pepperell Posted June 5, 2021 Share Posted June 5, 2021 In our coach the cloud has three 7/16” bolts along the street side, and hinges along the curb side, you’ll need a stool to see them. Using a socket wrench with a 3” extension unbolt the end bolts first then the center bolt. This cloud weighs upward of 60 pounds or more, so have some one ready to help lower it when that last bolt is removed. At that point all will be revealed. I have no idea what the factory used, my 2003 coach had 20 by 20 inch furnace filters. My 2006 coach has a/c loose foam type filters that can be rinsed and reused. When I ordered a replacement a/c I also ordered the plastic cover that would be used for a non cloud installation. It came with the loose foam type like you’d find on a home window a/c. Link to comment Share on other sites More sharing options...
Paul J A Posted June 5, 2021 Share Posted June 5, 2021 I replaced the OEM bolts with longer ones to accommodate the removal and re installing them. Much more convenient. Don't need to fight with the extension. Link to comment Share on other sites More sharing options...
Ivylog Posted June 5, 2021 Share Posted June 5, 2021 Yep, those ceiling decorations may look nice, but cleaning the foam filter is now a 20 minute job. Link to comment Share on other sites More sharing options...
Poohbear Posted June 5, 2021 Author Share Posted June 5, 2021 Ok I’ll have to look into it a little more . I tried but couldn’t figure it out. Thanks all Link to comment Share on other sites More sharing options...
