09 HR Navigator
Hi Don,
It appears there’s a 5amp fuse/ circuit breaker that feeds 12v to the red hat and Auto-Fill module, if that’s ok and the switch is functional ?? the Auto-Fill Module located on the front wall of the wet bay either has a bad connection or the module failed???
Hope this helps?
John C
2009 Navagator
John, I looked at everything I can think of and no luck. The fuse is good, the lights on the switch come on when toggled. The switch doesn’t control power going to the valve. My system has 2 blue wires going to one of the red wires on the red hat, that seem strange to me. The valve does click or make sign of trying to activate.
thanks
Don
thanks
Don
Don,
 Did you check the switch to see if it is grounded?
