Donnie Posted July 5, 2021 Share Posted July 5, 2021 My water auto fill has quit working. I have replaced the Asco valve and still doesn't work it still doesn't in either position. Any ideas? Thanks Don Link to comment Share on other sites More sharing options...
KevinH Posted July 5, 2021 Share Posted July 5, 2021 Do you have an Aladdin system? If so it must be turned on. Link to comment Share on other sites More sharing options...
Donnie Posted July 5, 2021 Author Share Posted July 5, 2021 No Link to comment Share on other sites More sharing options...
vito.a Posted July 5, 2021 Share Posted July 5, 2021 What ever system you use to monitor tank quantities must be on with properly calibrated quantity sensors for autofill to work. For most of us its Aladdin. Link to comment Share on other sites More sharing options...
jcavataio5255 Posted July 6, 2021 Share Posted July 6, 2021 Hi Don, It appears there’s a 5amp fuse/ circuit breaker that feeds 12v to the red hat and Auto-Fill module, if that’s ok and the switch is functional ?? the Auto-Fill Module located on the front wall of the wet bay either has a bad connection or the module failed??? Hope this helps? John C 2009 Navagator Link to comment Share on other sites More sharing options...
Donnie Posted July 7, 2021 Author Share Posted July 7, 2021 John, I looked at everything I can think of and no luck. The fuse is good, the lights on the switch come on when toggled. The switch doesn’t control power going to the valve. My system has 2 blue wires going to one of the red wires on the red hat, that seem strange to me. The valve does click or make sign of trying to activate. thanks Don Link to comment Share on other sites More sharing options...
jcavataio5255 Posted July 7, 2021 Share Posted July 7, 2021 7 hours ago, Donnie said: John, I looked at everything I can think of and no luck. The fuse is good, the lights on the switch come on when toggled. The switch doesn’t control power going to the valve. My system has 2 blue wires going to one of the red wires on the red hat, that seem strange to me. The valve does click or make sign of trying to activate. thanks Don Don, Did you check the switch to see if it is grounded? Link to comment Share on other sites More sharing options...
