fredelkamp Posted August 1, 2021 Share Posted August 1, 2021 We recently had our Norcold 1210 converted to a 12 compressor, making available a capped off gas line that I think would be perfect for installing an aux gas connection to use on our Blackstone griddle. Would this work, has anyone done this and what kind of hardware will I need? Link to comment Share on other sites More sharing options...
tmw188 Posted August 1, 2021 Share Posted August 1, 2021 (edited) Yes I have done the same thing on a different coach. Some parts you’ll need. Plan on doing it to this coach too. Edited August 1, 2021 by tmw188 1 Link to comment Share on other sites More sharing options...
nocreek141 Posted August 1, 2021 Share Posted August 1, 2021 I would be surprised if you investigated you would find a low pressure stub below the LP tank fill. Normally located under the coach, but easily accessed and stubbed out and capped 1/2" black iron pipe. Check it out. Mine was located there. I have '06 Cayman. Used some of the same item that are listed in the preceeding posts. I run my blackstone off of it. Good luck. Link to comment Share on other sites More sharing options...
tmw188 Posted August 1, 2021 Share Posted August 1, 2021 Find the shortest route however you do it. The parts I listed are low pressure. Link to comment Share on other sites More sharing options...
Ivylog Posted August 1, 2021 Share Posted August 1, 2021 Removed the oven/ cooktop and installed a induction cooktop plus storage below. Bought a single burner propane portable that we use inside hooked to the unused rubber hose … valve and a type C quick connect. Type C because I use my airline to supply propane to a portable campfire and the burner if using outside off the propane outlet in the fuel bay. Yes, I blow the air hose out before putting air in a tire. Link to comment Share on other sites More sharing options...
fredelkamp Posted August 1, 2021 Author Share Posted August 1, 2021 Thanks for all the great replies! Link to comment Share on other sites More sharing options...
fredelkamp Posted August 2, 2021 Author Share Posted August 2, 2021 2 hours ago, tmw188 said: Yes I have done the same thing on a different coach. Some parts you’ll need. Plan on doing it to this coach too. <snip> What would I need to connect this Quick Connect Adapter to my copper pipe in the picture? A 3/8" Flare x 1/4" Male Pipe brass tube fitting? Anderson Metals 54048-0604 Brass Tube Fitting, Half-Union, 3/8" Flare x 1/4" Male Pipe Link to comment Share on other sites More sharing options...
Ivylog Posted August 2, 2021 Share Posted August 2, 2021 I would not rely on just a quick connect on a propane line… add a ball valve before it. Link to comment Share on other sites More sharing options...
tmw188 Posted August 2, 2021 Share Posted August 2, 2021 (edited) Either one, the QD has a ball valve in it and is for LP and NG. It’s not a air fitting. You can buy what you need at any big box along with the gas valve above. Edited August 2, 2021 by tmw188 Link to comment Share on other sites More sharing options...
fredelkamp Posted August 2, 2021 Author Share Posted August 2, 2021 Thanks everyone, I went with the propane shutoff valve with a quick connect and the 3/8" Flare x 1/4" Male Pipe brass tube fitting to adapt it my fitting, we'll see when it all gets here if it all works. Link to comment Share on other sites More sharing options...
