eddie4ne Posted August 14, 2021 Share Posted August 14, 2021 We have had the problem with our right turn signal for the past several years. Occasionally it works on it own. We checked the bulb, it works. We changed the socket, same problem. A mechanic suggested rewiring from the side marker. Since we are not the most mechanically inclined we have not undertaken this task yet. Our work around is to manually push the turn signal up repeatedly when making a right turn. I would also note that the issue started when we wired our car to tow behind the RV. It was wired previously to pull our truck. I have opened the ends on the umbilical cord to check for loose wires and also the connection on RV and car. Everything seems secure. Any thoughts would be appreciated. Link to comment Share on other sites More sharing options...
klcdenver Posted August 14, 2021 Share Posted August 14, 2021 If you are using your tow vehicle lights you probably need a diode kit installed. Link to comment Share on other sites More sharing options...
eddie4ne Posted August 14, 2021 Author Share Posted August 14, 2021 We installed separate lights for towing in both car and truck we previously pulled. Before when we pulled only the truck, no problem. Now if we pul the truck, same situation, mostly doesn’t blink. Front and right side do blink always when signal is activated Link to comment Share on other sites More sharing options...
rpasetto Posted August 15, 2021 Share Posted August 15, 2021 Have you tried the signal without the toad connected? ... or ... Does the problem occur that way too? If it only happens with toad connected there could be a a bad ground or some other wiring problem in the toad's wiring. If the problem is still the same with the toad NOT connected, check for a bad ground in the RH lighting wiring. Link to comment Share on other sites More sharing options...
eddie4ne Posted August 15, 2021 Author Share Posted August 15, 2021 (edited) I does not work consistently without the toad connected. Edited August 15, 2021 by eddie4ne Link to comment Share on other sites More sharing options...
