TriMark bay door handle broke
We were camping this weekend and it was time to dump and refill the fresh water tank.
I pulled the paddle handle, and it partially broke. Fortunately I was planning on upgrading to chrome handles and I had the replacement on hand to study and replace the old one when I got it out.
The paddle operates a shaft with a cam on the end that rotates a plate that has four arms with holes for various installations. There is also a locking mechanism that prevents the plate from rotating when locked.
One end of the shaft is round (approximately 8.7mm) and the other is a Double-D (approximately 5mm across the flats).
I studied the replacement and was planning on drilling some holes to be able to rotate the plate, but when I examined the the failed lock I found I could pry the old paddle off and turn the shaft with a 1/4” wrench to get the bay door open and replace the paddle mechanism. I did have to drill out the hole that the lock mechanism shaft went into It was a little too small.
This handle is on one of the bays that cantilevers up. Note that Monaco riveted a plate over the lower section to provide somewhere on the handle to pull the bay door down.
Paul
Edited by pwhittle
  • 1 year later...
Paul
Hi , I'm new to the forum and was reading about your experience with your lock/latch/handle . It looks like you found a new chrome one . I am looking for a new white one for our 1999 Monaco Signature  . The only difference i see is the location of the key lock and the riveted on plate . If you have a part number and where you found it I would appreciate that information  . Enclosed is a photo of the one I need . Thanks  , Murphy
Try lookin here. Call they have great customer service.
https://www.trimarkcorp.com/sr/zPlatFormList.aspx?intcategoryid=12&topcategoryid=3&scategoryid=11
  • Thanks 1
I had to replace several on my 2000 Diplomat, they all came black, which I sprayed bony colour to match the original paint.
