gjh2916 Posted September 26, 2021 Share Posted September 26, 2021 Has anyone ever replaced the Kool Matic fan over the range with a third AC Unit? Just looking for options on adding a 3rd Unit to my 01 Dynasty. Link to comment Share on other sites More sharing options...
RustyTools Posted September 26, 2021 Share Posted September 26, 2021 We had an 'Atrium' model HR Endeavor several years ago. Finding that the big Atrium windows and windshield let in a lot of sun/heat in summer, even with the standard 2 AC units running on high, we installed a 3rd unit to replace the overhead kitchen vent. The coach had the standard 8k gen-set and had no problem running all 3 AC's at the same time, as long as we were attentive to what other appliances were also being used. I made a separate 120vac line for it that I could either connect directly to the power pedestal when parked, or run to the block heater outlet/breaker for use when on the road. Wasn't a very difficult job and it worked superbly, often joking that we could make now the interior cold enough to hang meat. Good luck! Link to comment Share on other sites More sharing options...
gjh2916 Posted September 26, 2021 Author Share Posted September 26, 2021 Ron that is good to hear, I was going to power it off the 20 amp dryer circuit, with a relay to control which appliance to operate, my coach didn't come prewired for a 3rd AC unit. Since I put 2 new Dometic Blizzard units on a couple of years ago, I was thinking about adding another 15K unit and controlling it with the CCC2 thermostat. Link to comment Share on other sites More sharing options...
RustyTools Posted September 26, 2021 Share Posted September 26, 2021 At first blush, I'd say your idea should work, Gary. Dunno though, if you have an EMS system, they can act strange at times. It's been a few years and I don't remember exactly how I wired it in the panel, but I think I switched out one single AC breaker for a tandem breaker in the main box. I used a heavy-duty DPDT-center-off appliance switch to control mine when changing power sources. As an aside, when I was redoing the power, I ran another line from each AC breaker in the panel to the floor area near the AC's and installed outlets so I could plug in little cube heaters when needed. That way, I wasn't doubling-up on drawing off big loads on a line. I also couldn't think of a time when I'd be using an AC and a heater simultaneously, so it seemed like an obvious choice. Link to comment Share on other sites More sharing options...
gjh2916 Posted September 27, 2021 Author Share Posted September 27, 2021 If my coach was factory wired for a 3rd AC unit. That is how it would have been done. I will just extended the dryer plug wiring to the new AC unit, and add a contactor to control which appliance gets the power. Link to comment Share on other sites More sharing options...
