Guest bobstromain Posted November 29, 2021 Share Posted November 29, 2021 ISL 400 noticed very slight leak under water pump. Found these under water pump. Can anyone identify. Bob St.Romain 04 Windsor Link to comment Share on other sites More sharing options...
DavidL Posted November 29, 2021 Share Posted November 29, 2021 (edited) They look like roller bearings. I would shut off the motor, turn the power off and wiggle all pulleys / pump above those bearings. If they are bearings, whatever they came out of is one minute from breaking. Plan on putting a new pump on no matter what...and likely a belt tensioner. Edited November 29, 2021 by DavidL Link to comment Share on other sites More sharing options...
Guest bobstromain Posted December 5, 2021 Share Posted December 5, 2021 The needle bearings in the photo turned out to be from the water pump. Removed belt and touched water pump pully and coolant poured out. so thankful I discovered this in my driveway. It would not have made it over a few miles. Link to comment Share on other sites More sharing options...
jacwjames Posted December 5, 2021 Share Posted December 5, 2021 16 minutes ago, bobstromain said: The needle bearings in the photo turned out to be from the water pump. Removed belt and touched water pump pully and coolant poured out. so thankful I discovered this in my driveway. It would not have made it over a few miles. Go buy a lottery ticket, your one lucky fella!!! Link to comment Share on other sites More sharing options...
Guest bobstromain Posted December 5, 2021 Share Posted December 5, 2021 I was so lucky that I feel guilty! Dave, thanks for your input Link to comment Share on other sites More sharing options...
