jjroxus Posted January 30 Share Posted January 30 I changed the oil, filter and the air filter on my Onan 12.5kw Spec B generator today. It has 4400 hrs approximately. My new to me coach is a 2002 Monaco Signature 40. Unfortunately there were no maintenance records available when I purchased the coach. Since the Onan is a SpecB model I assume it is not the original. I was wanting to change the fuel filter and belt. After removing the top panels as well as the side door, I could not find a fuel filter. Does it have one or is it using a feed from the Cummins ISL 500 fuel filtering system? I could see the belt and could barley touch it from the top access. It’s in really bad shape -very cracked. I’m hoping some of you have done this belt replacement before and can give me advice on how to access the belt to change it out and get the tension adjusted correctly. Thank you, JJ Link to comment Share on other sites More sharing options...
willbo777 Posted January 30 Share Posted January 30 You have to remove more panels to get to the belt. And the fuel filter is just behind the door and lower. You need to remove two bolts that are on the outside of the panel to allow the fuel filter to be pulled out for replacement. Onan Service manual2.pdf Link to comment Share on other sites More sharing options...
Hypoxia Posted January 30 Share Posted January 30 It's a time consuming job as there are somewhere around 2 million screws that have to be removed. Hopefully your Signature has the generator on a slide out for access. I bought everything from Cummins and replaced some parts as preventative maintenance. Here is a list of parts I replaced on my HDKCB Spec B: Onan HDKCB Spec B Parts 43 Belt, Drive 511-0219 $16.64 39 Water Pump 132-0448 39 Water Pump Gasket 132-0447 Coolant Pressure Cap 14 PSI 130-4320 39 40 Thermostat 130-6329 39 Thermostat Gasket 185-6004 38 Coolant Hoses 503-2500 503-2501 40 Water Temp Sender 193-0318 25 Oil Filter Adapter Gasket 122-0886 25 Oil Filter Adapter Plug Gasket 122-0884 40 Pipe, Water Return 503-2553 40 Clamp, Hose 185-6722 40 Clamp, Hose 503-2552 Onan HDKCB Service Manual.pdf Onan HDKCB Spec B Parts Catalog.pdf Link to comment Share on other sites More sharing options...
jjroxus Posted February 4 Author Share Posted February 4 Bill B2 & Jim C, Much appreciation for the manuals. I had not been able to locate it. My generator is on a slide. This helps out a lot. I sure couldn't see the fuel filter when I did the oil change. I'm going to have another look today. Getting at the belt will not be fun as it's on the back side of the slide out as you know. I'll have to get under the coach to get at the back side. I did have the top off and took off a half million of the screws and then replaced them when I did the other aforementioned maintenance. Looks like I will have to go for the full million to get the job done! Thanks for your insight, JJ Link to comment Share on other sites More sharing options...
